CLONESClosed-Loop Neural Simulations
clones is an
open-source interface
between
Brian, a neural
simulator for python users,
and
Sofa, a physics engine
for biomedical simulation.
clones allows you to
model animal behaviour through the interaction of neurons, muscles and
the environment.
Usage
Communication between Brian and Sofa is achieved through shared memory
and semaphores. The physical properties of sensors and effectors are
defined in the sofa scene description.
<Node name="Worm" >
<EulerImplicit /> <CGLinearSolver iterations="25" />
<MechanicalObject position="..." />
<Muscle name="ventral" spring="..." />
<Muscle name="dorsal" spring="..." />
</Node>
The list of sensors and effectors are passed as
parameters to a function called in a
network_operation :
import clones
@network_operation( when = 'start' )
def iteration():
clones.iteration( effectors = my_effectors , sensors = my_sensors )
This function sends effector values to Sofa and it updates sensor
values used by Brian.
Download
clones can be
downloaded
here. You will need to
install Sofa, Brian and posix_ipc.
Anonymous Subversion Access
The SVN repository can be checked out through anonymous access with the following commands.
svn checkout svn://scm.gforge.inria.fr/svn/clones
svn checkout --username anonsvn https://scm.gforge.inria.fr/svn/clones
The password is 'anonsvn'
